Help with MSD digital window switch
Old Aug 7, 2011 | 12:13 PM
Half-bred's Avatar
Default Help with MSD digital window switch
I need help with my switch. I'm having a problem with the RPM setting up. I don't know if the box is bad or something else is goin on. I hooked everything up the way it shows the white wire to #10 pin on the ecu and it is #1 for the cyl setup. but when I arm it and start it up the RPM it shows on the display is way off, I have all the wires hooked up except the gray wire. the yellow I have goin to the grounds but my main concern is the display of the rpm. Has anyone had this problem?
Old Aug 17, 2011 | 09:34 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Which MSD. Digital or old chip style?
Old Sep 18, 2011 | 09:49 PM
454navyss's Avatar
title says digital. im having a similar problem with mine, rpms show to be about 1/2 of actual rpm, i tried adjusting the "window" to compensate but it still didnt work, idk whats going on with it
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
