help with cam selection
Old Oct 26, 2007 | 03:05 PM
whitesilvy04's Avatar
I would call some of the shop sponsors on the side to get a better choice and what will fit you better...
Taking peoples opinions on a forum over the internet is not the smartest thing to do.. More then likely your going to be dissapointed with your cam selection unless you talk to the professionals. They can pick the right cam setup for what your looking for...
Old Oct 27, 2007 | 12:07 PM
sprayinLS1s's Avatar
11 Second Truck Club
id say 99silv. has the best advice, ive had excellent luck with www.thunderracing.com/ Im not for sure but you might have tranny heating issues running the stall and towing, unless you have a hell of a cooler on it, i got a tci3000 in a reg. cab w/ cooler not even towing and my tranny has got hot........if it was me with the weight of the vehicle not even counting when you tow with it id go with wider LSA, wont have as much topend but will make excellent bottom and good mid power, these two cams below would be good for what your doing.... i used the blower cam in my truck which is very similar to the cheater but specific to S/Chrgs.....drives excellent, idles well, slight lope and loves spray.......
99-TR-CHEATR-CAM Thunder Racing Custom Camshaft
"CheaTR" - 214/230 .601/.575 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam. $389.99
99-TR-CHEATRLS2-CAM Thunder Racing Custom Camshaft
"LS2 CheaTR" - 215/230 .629/.592 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Comp 921 Valve Springs are highly recommended. $389.99
Whipple and spray all the way.......
http://videos.streetfire.net/video/8...c800ef37d4.htm
Old Oct 27, 2007 | 12:22 PM
ajt86's Avatar
im using a derale trans cooler with electric fan mounted on it- so i dont think trans temps will be a big deal
im gonna give thunder racing a call on monday- thanks
Old Oct 28, 2007 | 05:22 PM
silver-mod-o's Avatar
Hunt&Fisherator
or you can talk to people who own and drive similar vehicles and probably have had 3 or 4 setups under them... This isnt the first one I've done... I dont give bogus advise bud.
Old Oct 29, 2007 | 07:03 PM
Okay dude, i dont know what your problem with me is but grow the hell up.. I dont know why your trying to start crap with me over the internet but if your looking to have a debate with me.. Take it to PM.. I never said you give bogus advice..
I really didnt care for you talking **** about my truck but i was cool enough not to let it bother me but if your going to start crap with me over a post that i wasnt directing towards you when you dont even know me... then take it to PM... Other then that have a good day...
Old Oct 30, 2007 | 06:46 AM
Hunt&Fisherator
no problem, I will
stock48
11
Aug 18, 2015 05:55 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
