Help 90% done ... So I think
Like the title says my wet kit is almost 90 % wired up, and off of the wot switch I have a power wire into it and and power wire up to the "arm" switch.. Then I have a ground wire from the switch to bolt in the frame, and a wire intO the fuse panel, and everytime I flip the switch it blows a fuse in that panel ... What do u reccomend me to do
They way i read that..
You need a:
hot wire from you fuse box to the arm switch
Wire from the arm switch to the WOT switch
other side of the WOT switch to a relay or the 'noids. ( i perfer a relay)
Ground the other leg of the 'noids
Your switch doesnt need a ground, unless you have an LED or indicator that needs a ground to complete that circuit..
You need a:
(If you use this and have a LED indicator on your Switch, the led isnt goin to work)
OR!!
you need a hot wire from the fuse box to the 'Noid
Other leg of the 'Noid to the WOT switch
from the WOT switch to the ARM Switch
from the ARM switch to a Ground
Both do the same thing, one is just completing the ground circuit, the other is completing the hot circuit.
OR!!
Thats how we did it, grounded one leg of the solenoids, ran other leg to relay, grounded the relay, ran power to the relay, ran the last relay wire in the cab to the wide open throttle switch, then the other side of the wide open throttle switch to the arm switch. We then ran a wire from the fuse box to the arm switch and grounded the other side. The solenoids tested good, hopefully he can spray soon
