Originally Posted by brizzle815
(Post 5228562)
I'm still unsure about my fuel set up.
I know now I'm good on my current injectors. I'm only wanting 150 shot I'm wanting to upgrade fuel pump for security. How much is a stock fuel pump pressure? Should I go with in line pump and keep stock pump? Should I go with in tank? Stock fuel lines ok? Do they need to be bigger Bosch or walbro pump? I'm wanting a fuel pressure switch for the nitrous? How do these mechanicaly work? If I get fuel pressure gauge should I monitor at pump or at switch? Sorry for the noon questions I just want to do this nitrous right Thanks In-line Pumps are a popular option. Stock fuel lines are fine. Either pump would be a good option. The way a fuel safety switch works is just like an on/off switch. if it has pressure it is on, if it drops below the pressure you set it to (user adjustable) the switch is off |
Get an AEM 320lph should be plenty for your setup. The in tank pump should be the way to go.
