First impressions of a 100 shot
what low dime said also rear bearing is out and the rear case half has to be changed to replace it. But a 4l80 swap is next on the list
Tach keeps malfunctioning, got a new cluster today has 2 miles on the odometer.
I agree i used to be able to slam them good with the v6, but now...the n/a video shows about the fastest shift i can manage with it.
Dustin
Dustin
Well got everything but the window switch fixed. No knock so far...but afr is like 10.0 so i need to lean it out BAD.
So i dont remember the jet thats in it, but how much smaller of a fuel jet should i go to...how much does a .001 actually make?
Dustin
Dustin
Last edited by 2005 Silverado; May 12, 2009 at 09:31 PM. Reason: edited for stupidity
what are the current jet sizes?
Fuel jet 0.027"
Nitrous jet 0.051"
thats what my calculator says for a 100 shot with 60psi fuel and 1000psi nitrous.
IF its rich, you should either put a smaller fuel jet or larger nitrous jet to lean it out.
Fuel jet 0.027"
Nitrous jet 0.051"
Well afr with the 100 shot was 9.98, so i used a calculator nonnie recomended, it said with the 33 fuel jet (which the plate kit recommends for the 100 shot) i needed the 150 hp shot jet. So i changed it out got he bottle pressure up to 1000 and went for it afr was like 10.2 but i was like wtf? so i let out and see the bottle pressure is like 700...so i guess im low on nitrous (this **** is a ******* hassle) So i guess a weak shot is causing the rich mixture. So before i call it quits im going to chill the bottle myself and have it filled and if i can get efilive to function right (AHHHHHHHH) I will see what a good strong 1000psi 150 shot feels like.
Well rant over, i am dissapointed.
Dustin
Dustin
Vortec350ss
Jan 12, 2016 10:36 PM
