effects of lsa and dcr on small to mild shot?
Old Nov 2, 2009 | 02:05 PM
fastrt's Avatar
11 Second Truck Club
Default effects of lsa and dcr on small to mild shot?
I am looking into a new cam with a 110lsa, with a duration split and around a 7.75 dcr. just wondering how a 110 will react to a 100-150 shot down the road. also mite mill the stock heads a bit and try to get scr around 10.25:1 and dcr around 8.5:1. I want to stay nitrous friendly with a little more N/A. wife put a stop on the 6.0 build, so I am trying to use the parts that I have already got laying around, nitrous, rod bolts, and some things I can send back for credit.
Old Nov 2, 2009 | 03:22 PM
MPFD's Avatar
Your power will peak faster in the RPM range.
Old Nov 2, 2009 | 04:16 PM
RandomHero's Avatar
I would be quite concerned with a 10.25:1 compression ratio and a 150 shot on the stock bottom end. At the very least I would run 93 octane and at least tr-6 plugs are maybe even two heat ranges colder than stock. I don't see the stock bottom end holding up long to those conditions though, but heck with the right tuning people are doing some crazy things with our engines.
EDIT-If it helps though we have almost the exact same setup and I am spraying a 150 shot with 125k miles on the engine.
Old Nov 2, 2009 | 05:40 PM
fastrt's Avatar
what cam do you have in your 5.3 now? I am just trying to find more out of the ol 5.3. the wife putting the stop on my motor build really pissed me off, so I am copeing with it by squeezing more out of the 5.3 under the radar. I am going to run tr6 plugs and all the nitrous safety stuff. I am planning on putting the kit on and building a wiring harness for it all this weekend. i know the tr224 will "work" ok but I want to max performance between on and off the bottle.
Old Nov 2, 2009 | 06:07 PM
TXsilverado's Avatar
im running 11.0:1 with a 150 shot and about to put another stage on. good tune, right plugs, rock on
yeah i know ill be pushing the bottom end pretty hard lol. stock rod bolts and everything
Old Nov 2, 2009 | 06:09 PM
nitrous works with all cams. it prefers split durations with a bias towards the exhaust though. if you like the 224 cam, just step to a 224/228 or 224/230. 110 lsa is pretty low on that cam with a 5.3 though. i would step it up to atleast a 111 or 112.
Old Nov 2, 2009 | 06:13 PM
RandomHero's Avatar
I'm running a comp 224/224 on a 112 lsa, pacesetter longtubes, ss3600 converter, efans, intake, full 3" exhaust, cutout, etc.
As far as the nitrous I'm running a nitrous express kit, HSW plate kit, NE purge, bottle heater, fpss, wot switch, window switch, bottle pressure switch. I'm also running tr-6 plugs and I am running a custom operating system in EFI Live so when I flip my nitrous switch it immediately retards 4.5* of timing and progressively retards up to 6* at 6400 rpm when I shift.
No track times, because my truck suffers from a bad vibration at 5-10 mph, but the best time to date with that setup with only an 8.9 at 81mph with a 2.2 60'. With the converter it should be doing solid 1.8s easily which would put my 1/8th mile e.t. around an 8.3. But of course that's in a perfect world.
Old Nov 2, 2009 | 06:16 PM
BlackGMC's Avatar
Resident Retard
COS5 right??? If so it must me nice, they stopped making them COS5 for the 1mb PCM...
Old Nov 2, 2009 | 09:11 PM
bluecajun5.3's Avatar
yeah them bastards
wonder if we could switch to a 512mb?
i would rather that so i could be more consistent with my bracket racing with a cable style tb.
Old Nov 2, 2009 | 09:28 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by bluecajun5.3
yeah them bastards
Actually, i believe you might be able to i stumbled across some settings in EFI live that might make this possible, i am not sure how you would go about wiring in the new TB sensors thou...
check out this screen shot.... I wonder what would happen if you turned off the electronic Throttle setting??/?
Attached Thumbnails effects of lsa and dcr on small to mild shot?-screenshot.jpg
