Dry shot going way lean off the line. HELP!
Old Dec 28, 2006 | 02:35 PM
Default Dry shot going way lean off the line. HELP!
I have a compucar dry kit with all braided stainless line and a single .073 jet. It bogs bad and goes way lean for about 2 seconds, then it hauls ***. How do I tune out this extremely lean spot? I doesnt matter what speed I'm going, its just the first 2 seconds of spray. Once it gets moving the O2's read a fairly steady .850-.875. I wish santa would have gotten me a wideband. lol
Old Dec 28, 2006 | 04:01 PM
speedy02's Avatar
What size injectors are you running? It's hard to get a accurate reading of the AFR at WOT with stock narrow band O2's. A Wideband is a must when spraying.
Old Dec 28, 2006 | 04:38 PM
I have 38.5# injectors. I normaly run 60% DS N/A and I was running 77% DS with N2O and richer PE.
Old Dec 28, 2006 | 05:53 PM
onebadrubi's Avatar
with it bogging you sure its not adding too much fuel? Lean should actually make Ping or HAULASS. rich normally is bogging.
Old Dec 28, 2006 | 07:43 PM
there is no ping, but the O2's drop to nearly 0 and after the bog is gone they go to a steady 850-875.
Old Dec 28, 2006 | 08:40 PM
I fixxed it. I moved the nossle and played with the PE some more.
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
twake_410
Apr 14, 2016 09:58 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
