Cutting -6 AN line
Old May 14, 2019 | 06:56 PM
Patrick05's Avatar
Default Cutting -6 AN line
What’s everyone using to make clean cuts on the -6 stainless braided lines? I have fittings from Russell performance and nice stainless braided line but can’t seem to get a clean cut. Iv tried tape and everything but end up stripping the end out and don’t really wanna do it again considering they’re $10+ each. Any suggestions?
Old May 14, 2019 | 10:04 PM
skolman91's Avatar
Summit sells a cheap pair of cutters that work good that also comes in handy on thick wiring.
ive used a really sharp chisel and tape in the past and one or two quick hard hits and its cut and u have to reshape but leaves a clean end.
seen some use fine tooth hacksaw but that leaves a mess imo but it works.
Old May 14, 2019 | 10:41 PM
Patrick05's Avatar
well I bought a 6” cut off saw from harbor freight that I thought would work perfect. And didn’t work out too well.
Old May 15, 2019 | 05:22 AM
RySmDPT14's Avatar
I used a pair of cutters specifically for ptfe from summit and they worked ok but not very well left many of the SS strands and ragged edges on ptfe. I used a very nice set of tin snips to finish it off. eBay has them very cheap 20$ or so
Old May 15, 2019 | 08:02 AM
Lonnies Performance's Avatar
LS1TECH Sponsor
Buy a rotary cutoff tool or die grinder (air or electric) with a .3" dia 040-.062 thick cutoff wheel.
Put 2 wraps of masking tape over the line & cut through the tape.
It will leave a clean edge.
Old May 15, 2019 | 11:56 AM
Patrick05's Avatar
Thats kinda what I have but I believe the wheel is 5-6” or so. Iv tried the tape but doesn’t seem to cut very cleanly
Old May 15, 2019 | 12:10 PM
Patrick05's Avatar
Old May 15, 2019 | 12:34 PM
LS1TECH Sponsor
A 5-6" grinder typically has a much thicker wheel.
Also black tape does not hold the braid tightly enough...it stretches from the heat of the cut & allows it to fray.
Old May 15, 2019 | 12:58 PM
TXsilverado's Avatar
my best results are from clamping a hose clamp over the hose where i plan to cut, and run a 4" grinder with a thin cutoff wheel across the top of the clamp. It makes for a straight, clean cut. Blow compressed air through the hose from the opposite end to clean as much of the rubber dust as possible.
this gives me consistent clean cuts in comparison to using electrical tape.
Old May 15, 2019 | 01:30 PM
arthursc2's Avatar
I do the exact same thing! And the clamp can be ever so slightly loosened and slid down, it makes getting the nut on infinitely easier! No fighting frays
