Can the Iceman noid support a 200 shot?
Old Apr 21, 2006 | 11:00 AM
slowprocess's Avatar
Default Can the Iceman noid support a 200 shot?
Just curious. It's a big damn noid, but I've heard its good for only 150. I've seen larger noids support more than 150, so I'm wondering what the Iceman can really handle. Plus, I like using the word "Iceman"........Maverick out.
Old Apr 21, 2006 | 06:30 PM
goshawk23's Avatar
Truck addict
nah, there junk. i have the perfect noids for you. i'll have them ready for pickup when you come down.
on a serious note, do they still sell them under that name? if so i would check nx to see what they rate them at. i am sure nitro dave will have a quick answer for you though.
Old Apr 21, 2006 | 08:05 PM
goshawk23's Avatar
Truck addict
oh and uh, i think they can support over a 500 shot accroding to the nitrous section on tech.
Old Apr 21, 2006 | 08:08 PM
goshawk23's Avatar
Truck addict
i found this on tech also
You would not happen to have installed an NX IceMan Nitrous solenoid, would you? The nitrous outlet is on the bottom of the solenoid. The outlet directly across from the inlet is for a purge solenoid on the IceMan noids
did your noids have a outlet on the bottom? if so i don't remember putting the lines on it that way.
Old Apr 22, 2006 | 08:52 AM
Yeah the line is out the bottom. I saw on the noid where the purge is on the side.
Old Apr 25, 2006 | 11:46 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
The Icemans can support a 300 hp shot..
THe shark nozzle will support a 250 hp shot.
The stock hose from the nitrous solenoid to the nozzle will max out at a 175 shot.
You will need to upgrade to a SHO Hose to go higher.
Dave
Old Apr 26, 2006 | 01:58 PM
Dave
I appreciate the response on this!!! Upgrade to the SHO Hose in the NEAR future.
twake_410
Apr 14, 2016 09:58 PM
Wrecker 426
Oct 7, 2015 12:11 PM
turbo6c3
Oct 5, 2015 06:11 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
