Bottles under the seat?
Old Jan 14, 2011 | 07:09 PM
RSTinOKC's Avatar
Default Bottles under the seat?
Ideally I want to be able to have at least 15lbs at the ready, but I'm pretty sure a single bottle won't fit under either of the seats.
RCSB with a speaker box behind the seats, so you see my dilemma and I'm just not too keen on mounting the bottle in an uncovered bed.
Ideas and suggestions are appreciated.
Old Jan 14, 2011 | 07:13 PM
viciousknid's Avatar
Where's the Beef?
jump seat or full console?
I've contemplated modifying the bottom of my jump seat to accommodate a 10lb bottle
Old Jan 14, 2011 | 07:22 PM
RSTinOKC's Avatar
Hmmm...jump seat.
I will look into that; I kinda wanna keep stock appearances in case I ever want to show it but it should be easy enough to "gut" the jump seat...I dunno.
Old Jan 14, 2011 | 09:35 PM
SRTKLLR's Avatar
Did just that on the Hemi in my sig. I put two 5lb bottles there.
Here is a pic.
Old Jan 18, 2011 | 10:15 PM
smok'nZ's Avatar
MASS seller approved
buy a bed cover im sure you could use a nano system too
Old Jan 18, 2011 | 10:19 PM
StrokerAce03's Avatar
You could get a small toolbox and put it in there.
Old Jan 18, 2011 | 10:35 PM
Red Truck's Avatar
cut a sealed hole in your speaker box maybe?
I had a buddy who cut his speaker box open, mounted a bottle in there and hinges on the piece he cut out so he could get it in and out. Was pretty trick.
Old Jan 19, 2011 | 08:05 PM
RSTinOKC's Avatar
Toolbox is actually an option because I have one atm, I'm on the fence as to if I'm going to keep it or not.
I like the speaker box idea too.
Definitely some food for thought here.
Old Jan 19, 2011 | 08:10 PM
Where's the Beef?
Here is a pic.
were you not able to keep the original seat and just gut the bottom out? That is basically a part of a home made seat slapped ontop of a couple bottles.
Old Jan 19, 2011 | 08:16 PM
TXsilverado's Avatar
i always thought it would be cool to mount a big bottle to the frame under the bed. stealth and function. it would just be a PITA to fill bottles.
