5.3 200 shot
willit hold up on window switch
Window switch will mainly help your tranny, unless your just talking about to keep it from hitting before 3k rpms.
But if i wanted to spray a 200shot IMO i'd run a progressive controller rahter than have the 200 hit all at once. |
Originally Posted by TouchOfEvil04
(Post 3950563)
If this is on a stock motor I want video of it the first couple of time you try it out especially if it is not on a progressive controller.
200?? aaaaaahhhhhhhhhhhhhhhhhh!!!!
200 on a stock motor??? i dont see that lasting to long at all
Originally Posted by chevrolet all the way
(Post 3950788)
A fairly local guy down here has a 5.3 running a 200shot on it a few bolt ons. Engine is fine tranny has gone out a few times though lol. |
I have run a 150 on a completely stock engine, when my truck gets done, if ever, I plan on seeing how far a stock bottomed 5.3 will go. I have the trans to support it TH400, hopefully the t-case and diffs will too. I plan on running a 2 stage, 150 out of the hole and 100 whenever i get traction. If it holds im just going up from there.......
Theres a shop here that had a 300wet on a all stock vette 5.7ls1 as one single stage, just to see how itd hold up, they had it dyno tuned. and if i remember right they said it lasted two 10lb bottles worth.
5.3 will take 300 on a dual stage with a good tune. I wouldn't do 300 on a single but 200 is very doable. Make sure your tune is on and go for it if you got the trans.
