1999 gmc sierra 5.3 truck norris cam nitrous tuned
I have a 1999 gmc sierra with 5.3 with btr truck norris cam and it is tuned for a wet 50 shot of nitrous but the kit i bought has the lowest shot of 75hp and i was wondering if it would need more timing pulled or would it be good? Havent tested it out gonna also use ngk tr6 spark plugs. Any ideas?
I've run a 100 shot without pulling time (27* total degrees) but you can't go buy any arbitrary number because you already could be close to knock. I'm pulling 4* on my 150 shot. I wouldn't run the TR6 projected tip plug it may cause knock. If you want that heat range run the BR6EF from NGK. I'm running the BR7EF a step colder with no idle or fouling issues.
