Is a 100 shot safe?
Old Mar 27, 2008 | 10:41 PM
WJ MARK's Avatar
Much easier to run a wet 100 shot and not mess with anything else. I like mine wet!
Old Mar 28, 2008 | 12:06 AM
chris04's Avatar
ok guys so i sprayed the truck with a 75 shot, the kit is a spacer plate with the shark nozel coming up thru the bottom with the gas line and nitrous line, along with the 2 solonoids for the nitrous and gas, had my tunner pull timing and richen it up so there wouldn't be any sparknock, truck ran awesome picked up a few tenths with it, i ran a 12.803@ 105 with a 1.802 60ft and a 8.003 i think in the 1/8, so i would like to bump up the jets to a 100 shot next time and try that out. thanks for the help also guys
Old Mar 28, 2008 | 08:00 PM
ZeroTraction's Avatar
what was your old best time? are you runnin a window switch or what? how did the truck take it? could you tell a diff when it kick on? im lookin to run a kit on mine soon also....just need to install it and tune for it
Old Mar 28, 2008 | 08:53 PM
chris04's Avatar
my best last time was a 14.2 with just cam and tune with shorty headers, since then ive installed 4.10 gears along with a yank ss3600, electric fans and a cai and some m/t slicks. and no im not running a window switch i got a toggle switch with turns the soloniods on and then i have a button for the spray, and yes i could tell a difference the motor sounds like a higher pitch if that makes sense, and yes the truck took it well, i had my tuner pull out some timming and riching it up so it wouldn't spark knock so i sprayed it straight out the hole and all the way thru the shifts so basically i held it all the way down the 1/4. it gave me atleast .5 tenths in the 1/4, and believe me its addictive. i plan on spraying it next with a 100 shot.
Old Mar 28, 2008 | 09:09 PM
chris04's Avatar
by the way i prob could have got mid 12's if i could have got the bottle pressure up more, it was low the whole night. so maybe next time a better time.....
natejk
Nov 15, 2016 08:05 AM
twake_410
Apr 14, 2016 09:58 PM
zblee
Nov 11, 2015 12:41 AM
Slammed silverado
Sep 28, 2015 06:14 PM
chopperloco
Sep 28, 2015 08:40 AM
