**Nitrous Question**
Old Apr 17, 2008 | 10:56 PM
graysilv's Avatar
Default **Nitrous Question**
i have a dry nitrous kit that i havent used in a while. this is what i have.....
bottle
nitrous solenoid
nitrous main feed line
wot switch
i was thinking of buying a dry to wet conversion from harris which is the fuel and nitrous solenoid and the nozzle. Will that complete a wet kit or do i need something else? Also will the current main nitrous feed line work with the Harris nitrous solenoid or would the fittings be different? And last can i use the old nitrous solenoid as a purge?
Old Apr 18, 2008 | 01:09 AM
WFOsierra's Avatar
The dry kit prolly has either 4AN or 6AN fittings. Just make sure that your get the same size fittings, And you will prolly want to get a realy to wire up the solenoids.. but check with harris i just bought a wet kit new for 399 shipped, might be cheaper to get that and then sell the dry kit, it might be a cheaper route, plus they have great quality stuff..
