Noob from PA w/ 2002 tahoe. any performance recommendations?
maybe you all can give me some good websites to find these parts that have reasonable deals. and by changing the gear ratio in the rear axle will that mess with the 4wd when engaged?
before considering gears, check to see what gears you have theres a list of codes in the glove box find which one of these you see and that will tell you:
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
With rims that big it is going to be hard to be fast... that is why I stopped at 2's and I still have a huge disadvantage. If your on a budget I would say spray if not I would bite the bullet and put 4.10 gears in the front and back which will wake that truck up! It has take alot for me to be close to alot of the semi stock trucks on here SUV's are heavy.
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
bsgiffor
Jul 19, 2015 11:14 AM
