Newbie needs a Lift?
Old Nov 30, 2015 | 12:51 AM
ckown's Avatar
Registered User
Default Newbie needs a Lift?
Hello 08 1500 4wd-Toyo 235/65/18 (34.6/65/18)
already have the wheels and tires. Would appreciate any advice to what size lift i need. Thanks in advance.
Old Nov 30, 2015 | 10:40 AM
FFDP's Avatar
Why a 235 tire?
Thats way smaller than the 265/65/18 stock size, you wouldnt need a lift at all to run that, it'll just look goofy.
Old Nov 30, 2015 | 12:18 PM
ckown's Avatar
Registered User
My bad I had a beer in my eye.
325/65/R18
Old Nov 30, 2015 | 02:00 PM
GM1697's Avatar
I ran 305/65/18 Falkens on my truck with just the torsion keys cranked up 2 inches. They didn't rub at all even at full lock with 2010 z71 wheels, 18x8. If you still have the stock wheels then I imagine you could run then with just a torsion key lift, might rub a little seeing as they are wider than what I had.
Old Nov 30, 2015 | 06:56 PM
ckown's Avatar
Registered User
Took my tires to DT and the sold me the wheels. I explained to the i had cranked 4 notches to get somewhat level and there was probably 8 or so more. They just said it scrubbed at the slightest turn of the wheel and I needed a lift but wasnt sure how much. maybe ill raise keys to the limit and go back and have them mount and balance.
Thanks
Old Nov 30, 2015 | 07:55 PM
FFDP's Avatar
07+ NNBS trucks do not have torsion bar keys on 1500 models. 2500's have them.
I'd say more than a leveling kit will be needed to not scrub alot. It won't ride like a dream either with super heavy rim/tires and a lift.
Old Nov 30, 2015 | 08:13 PM
ckown's Avatar
Registered User
I was assuming the cam shape washers that are tached to the front and back of each arm that have tic marks?
Old Nov 30, 2015 | 08:14 PM
FFDP's Avatar
Those are to adjust camber and caster.
Old Nov 30, 2015 | 08:36 PM
ckown's Avatar
Registered User
Freakin awsome
Old Nov 30, 2015 | 09:12 PM
FFDP's Avatar
Yeah, these things are camber/caster adjuster.
http://www.andysautosport.com/images...1_20100801.jpg
