New from Mississippi rcsb cam question
Old Jun 18, 2019 | 12:13 PM
Horsetrader's Avatar
Default New from Mississippi rcsb cam question
I have a 99 rcsb Silverado with a bone stock 4.8. Long tubes and exhaust. I'm tossed up between btr stage 3 and 4 truck cams. It currently has 3.42 gears Will not pull a trailer just looking to build a fun driver. Any insight with cam and converter would be appreciated.
Old Jun 18, 2019 | 03:00 PM
madmann26's Avatar
The stage 4 is too big.
Stage 3 is big but if you had more gear or a stall it’d help out a lot.
As for stall, the CircleD 3200 HP model is well liked and proven.
Also think about this,
After you spend all that money on the 4.8, cam, springs, pushrods, gaskets, etc you could just about get an lq4/lq9 for a little more and walk circles around the 4.8.
Just food for thought.
Old Jun 18, 2019 | 03:49 PM
FFDP's Avatar
I agree with the above.
If you're dead set on a camshaft, I'd look into the 212/218 size or whatever the stage 3 is with a stall converter.
Don't forget you will need/want larger injectors if they are stock.
Old Jun 18, 2019 | 05:14 PM
I have considered ditching the 4.8 just hate to waste a good running engine so I'm going to see what i can do with it but I'm sure it will have a 6.0 before its said and done.
I've been leaning towards the stage 3 just wasnt sold on it completely. I have new lifters springs and injectors to go in when I do the cam and converter
Old Jun 18, 2019 | 05:54 PM
TrevorH's Avatar
Welcome from SW MS!
Old Jun 18, 2019 | 07:23 PM
Originally Posted by TrevorH
Welcome from SW MS!
Thanks. What part of MS?
Old Jun 19, 2019 | 02:31 PM
TrevorH's Avatar
Between Brookhaven and McComb.
driver_rs1
Mar 9, 2008 02:46 PM
72f100
Jan 19, 2007 04:43 PM
Aug.T
Sep 27, 2006 08:14 PM
Bondo
Oct 6, 2005 10:27 PM
Bondo
Oct 4, 2005 03:02 PM
