Short clip 25-75.
Slowest turbo build ever!
Nothing special... Havent driven the truck in almost a month while I had a brake line out of comission. Got it fixed then the next day my fuel pressure regulator died on me. So I replaced it Saturday and took this video while I was out making sure the new one worked just fine
i see you have a KBracing turbo kit waiting to be installed man i would love to put one of those on mine truck but since i have high compression probably won't work out so good
25-70 run. - YouTube
.25-70 run. - YouTube
You could always sell your heads and get new heads with proper gasket thickness to lower your compression ratio so you can run much higher boost safely..
Id like to but there really isnt anywhere close to my house that I can run it up that high safely... Besides, I dont know if my phone will record long enough for me to hit 100
Sure it would, think diesels...
I bet you could run one just fine if set up right. But im sure your truck runs awesome the way it is. Thats about the same engine set up I want to put in my S10 someday.
.I bet you could run one just fine if set up right. But im sure your truck runs awesome the way it is. Thats about the same engine set up I want to put in my S10 someday.
