MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Rematch with the lightning..
Old Dec 30, 2010 | 01:18 PM
tiffo60's Avatar
Originally Posted by GodBuiltMy5oh
It depends on set up. My L is built, heads cams, unported blower at around 12psi if I had to guess. It hooks perfect from a 20 hit. From 30 it roast the tires though.If you truck is still trapping 106, I feel sorry for that lightning. Unless the timing was low for 91. Props for staying in until he passed you though.
Mine was a full bolt on L with a KB @ 15psi, it didnt matter where you hit it from in first gear it was going to blow the tires off, it would do it in 2nd around 55-60 if the weather and payment was cold enough. The only way it would hook on the streets was with slicks...
Old Dec 30, 2010 | 02:35 PM
GodBuiltMy5oh's Avatar
I just wanted to give an example that not all built L's around 500 have issues from a 20. Of course some don't hook. Which is why I said, depends on setup. Or should I say ENTIRE set up, but I thought thAt was understood.
IMO for the street, eaton and spray is better than a twin screw.
Old Dec 30, 2010 | 06:38 PM
Jake99's Avatar
I agree, the twin screw sc makes crazy torque and makes it vary hard to hook, his big heads and cam dont help eaither, seems like the power dont come in till 25-30 mph. He has nitrous on it but hasnt used it yet but i think it going to be meen on the bottle. And yeah his timing is low but im not shur how low. I havent done anything to mine other then a little taller tire sence the 12.5 at 106 run, but you also have to remember are da sucks out here i bet mine would go 11s at a sea level track.
Old Dec 30, 2010 | 07:19 PM
My heads/cams raised my curve. My truck was total garbage below 2100ish rpm's. But it didnt have any low end roll/dig issues. Although since my trans was going out it took 5 minutes to shift gears.
I used to spray a 150 shot. Good lord did it wake up....and detonate
Old Dec 31, 2010 | 02:24 PM
05_GMC's Avatar
Jake so you were running n/a right. what he come by you at 115 120
Old Dec 31, 2010 | 04:20 PM
Jake99's Avatar
Yeah im na, I think he may have come by me a bit sooner then that, I go into third and hes on top of second gear when he starts to pull, so somewere between 100 and 110 i think.
Old Dec 31, 2010 | 04:28 PM
Jake99's Avatar
This vid is whan he was on e85 and 15psi, we bothe went from a stop and my old tires werent hooking for nothing, it looks far but he had me about 4 to 105ish
http://s832.photobucket.com/albums/z...JakeVSeddy.mp4
this is also from a stop when im on a 75 shot, hit the spray when i got into 2 gear and shifted at 6200 cause my trans wasnt shifting good anymore, top end looks much better when i use a power adder also..
http://www.youtube.com/watch?v=g2bu_rkLfoc
Both runs were when he was on e85
Old Dec 31, 2010 | 04:34 PM
05_GMC's Avatar
**** yeah thats what im talking about i know you would have got him on the kit. The ls engine touched by the hands of god
Old Dec 31, 2010 | 04:49 PM
Jake99's Avatar
Thanks man, im happy with the way it runs for the budget i was on when i built it, these ls engine are the ****!
Old Jan 1, 2011 | 11:14 AM
Good lord, spray for the win! I love it.
