MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Phantom testing 'The Bruise' on the STREETZ
Old Nov 7, 2014 | 05:23 PM
Phantom's Avatar
11 Second Club
whatever you guys are doing is working. I just noticed the slight unload in the clip at .32. I see the initial hit, then a slight unload, then it settles back in. I'm curious if it would do any better if you were able to go a hair tighter on the extension to get the initial hit under more control to avoid the little bit of unload. I'm sure it does perfect on a prepped track.
There's quite a bit we can do to make it leave even better. This was only the 2nd and 3rd passes with new trans and converter and tbrake and 2step. And only my 3rd pass ever in the truck. We basically went out last night to prove a point after a week long debate on the facebook page that you don't need coil overs on the front at our power levels.
Old Nov 7, 2014 | 05:28 PM
TXsilverado's Avatar
glad I'm not a facebooker. not necessary, but a little weight savings and ride height adjustability is always nice. has anyone found a light rate spring that works on the full size yet? The truck seems to transfer just fine. that's something I could never get my extended cab full size to do.
Old Nov 7, 2014 | 05:31 PM
Phantom's Avatar
11 Second Club
Don't get me wrong, if we could afford them, we'd have them. Just not necessary and money can be spent elsewhere or saved. You can use any spring you want. May just not be a bolt in deal
Old Nov 7, 2014 | 06:07 PM
dirt track racer 81's Avatar
I'm going to check the spring rates on these springs and go from there.. Getting springs is no problem..
Avalanche2002
Nov 30, 2015 07:31 AM
BlownHD
Oct 3, 2015 12:24 PM
97_ek
Sep 23, 2015 09:16 PM
jfuegner
Sep 22, 2015 12:30 PM
12secSS
Sep 16, 2015 03:59 PM
