New after stall/built tranny videos!
Looking at his log, the reason the speedo is on crack is because his tires are spinning some.... Even with them spinning, his truck really moves like that, like i said earlier i was shocked!!!
Wearin' da big hat
My tires are 265/70/16s. Theyre just micheline truck tires.
Also, as far as cruising goes, at 30 the converter will be unlocked so the RPMs will be between 2400-4000 depending on how much gas you're giving it. You can DD this converter under 3200ish. And cruising at 70, the converter is locked, so it is just like driving with a stock converter.
