MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
My 4x4 Maggied 5.3 vs 2011 Mustang GT 5.0
Old May 15, 2011 | 10:54 PM
  #31
04Burban's Avatar
Originally Posted by swift700
Well, this weekend's fun has taken its toll. My 4l60e is toast. It's slipping in second so I assume I burned out the 2-4 band. I thought I felt it slip in 4th without the converter locked, too. Now I have some work ahead of me.
Does anyone know the company that makes that nice crossmember for the 4l80 swap? It looks like a tubular factory piece and was pretty cheap if memory serves me correctly.
Another option is to drop the trans and change the band. I'd throw in a Vette servo, too. I have both parts here.
What would you guys do? I want to get racing again.
FLT makes the 80. As "spirited" as you drive you need it. It would be a waste of time and resources to fix the 60
Old May 15, 2011 | 11:20 PM
  #32
swift700's Avatar
I have the 80e sitting on my garage floor along with the cooler lines and transfer case input shaft. I just need a crossmember and some driveshafts. I think I'll just mod up my crossmember and do the required wiring. I will leave the driveshafts up to a local guy here who does good work. As far as the segment swap goes, I'm little lost.
Old May 16, 2011 | 12:37 AM
  #33
AKlowriderZ71's Avatar
11 Second Hall Moniter
Segment swap is cake. There is a writeup for it on the HPT forum.
Another reason for you to buy HPT.....
Old May 16, 2011 | 04:40 AM
  #34
TIM Z's Avatar
11 sec. Truck Mod
EFI Live has a sticky also how to do this, if i can do it you can do it ! Its`EASY!
Dont waste any more time on that 60e.
Put the 80 E in and be done with it.
If you redo the 60 it WILL fail again, With your truck, wieght, power level, And as fast as the power comes on, a 60 e will NEVER last. I know this!!!!!!
Old May 16, 2011 | 10:29 AM
  #35
swift700's Avatar
OK, my mind is made up. I'm ordering HP tuners and putting the 80e in. I was hoping to go with a stall but they are so damned expensive for those trannies.
Old May 16, 2011 | 04:00 PM
  #36
TIM Z's Avatar
11 sec. Truck Mod
Good for you bro! You made the right choice.
Lemme know if i can help, i just went thru this ordeal!!
Man i love the way the 80 shifts though!
Old May 16, 2011 | 07:41 PM
  #37
black04's Avatar
Nice run. Race city is horrible. When i ran there in my rcsb it went 13.5 as well. Just going to a different track drops .4 seconds at least.
Old May 16, 2011 | 10:40 PM
  #38
Good choice on the 80E and HPT. Don't look back!!
Old May 16, 2011 | 10:57 PM
  #39
swift700's Avatar
I'd like to do a bit of practice tuning on my current 5.3 before the swap but now that I need to do a tranny I'm thinking that I'll do it all at once. I hope I don't regret this.
And yes, the track at Race City is slippery. I have a vid against a Duramax where you can see all four tires spinning. I hook better on the street. It was opening day though so hopefully it improves some as things heat up.
Old May 16, 2011 | 11:32 PM
  #40
black04's Avatar
The DA is ridiculous as well. I think elevation is around 4000ft but da is usually 5-6000ft.
