Couple vids of the truck!
Just did short block. Heads are the L92's that come on the truck with swapped LS3 intake valves (hollow stem) and valve job and deshroud. Factory truck intake with some port work. Cam is a comp 232-238 dur / 604-607 lift / 112+2lsa (small for the motor) but intake is the limit right now!! The truck put down 420rwhp & 405rwtq. Expect it to increase some with full heads and intake swap, not to mention bigger cam & 250shot
Sure that Dmax get better fuel mileage if your into that sorta thing!
Oakley6575- what does your truck run? And crew cab or single cab? Just curious as to what mine might/should run?
