MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Cam Swap & DOD Delete on NNBS By TooTall
Old Mar 7, 2010 | 05:58 PM
  #31
max1's Avatar
Banned
i ran with those tires^^ and they hook nice...
Old Mar 7, 2010 | 07:24 PM
  #32
Luke03's Avatar
Originally Posted by Tootall
you're not the only one . . . I made Nick put his cutout back on too . .
It's usually late in the night when someone leaves . . . if it was the day time . . . that's a different story.
I had to cut his y-pipe right after the headers. . . . I don't have a welder
None the less man great work! I might be picking up that shortblock from you... for a kinda long term project
Old Mar 7, 2010 | 07:39 PM
  #33
Tootall's Avatar
Originally Posted by gtosilverado
ill put up some walkaround vids after its tuned and stays on, lol
please do . . . it was too late to hear the idle and enjoy it . . . .
Originally Posted by dlt76028
That sucks you have to change out the lifters on the DOD trucks. I would have put some ported heads on there too.
it already has the 243s on it . . . so it's not a total loss
Damn your camera picks up every little noise
One of these days Matt Ill make it by to pick up my damn channelocks
yeah it's very sensitive!
I use those channel locks just for the stupid GM hose clamps .... works perfect!
what u guys think it will run full weight......... ??
12.75 !!!!
You better hurry, . . . there were a few guys that had their eyes on it this weekend. It might have a new home . . . .
Old Mar 10, 2010 | 12:00 PM
  #34
Preston129's Avatar
What needs to be done with the PCV valve on the new valley cover? I've read on the 6.0 in the g8 they plug the one in the driver side valve cover and run a new tube from valley cover to intake. Is this the same thing on these motors?
Old Mar 10, 2010 | 03:14 PM
  #35
Tootall's Avatar
it's to your advantage to use the new PVC in the valley cover and keep the oil out of the intake.
The two breathers on the valve covers can be completely blocked off.
Old Mar 10, 2010 | 06:33 PM
  #36
Preston129's Avatar
So where do you vent the PCV tube from the valley cover? As it is now, I have the driver side breather going from the valve cover to the top of the intake manifold, and on the passenger valve cover to the CAI tube.
Old Mar 10, 2010 | 06:48 PM
  #37
Tootall's Avatar
cap off both valve covers.
cap off the top of the intake - this is the vac supply for the drivers side.
get a longer hose, and run it from the intake TB vac (that used to goto the driver's side) to the new location on the valley cover.
With the new LS6/7 valley cover, you only need one suction point.
If you have a catch can, you can plum all 3 lines into a catch can, and then into the intake.
Old Mar 11, 2010 | 06:32 AM
  #38
Preston129's Avatar
Ok, yeah that makes sense, thanks.
I'm curious if you measured preload with those 7.4 rods, what the measurement was?
Old Mar 11, 2010 | 02:02 PM
  #39
Tootall's Avatar
no I didn't. Owner ordered parts. I did mark and spin the motor over after marking the valve tip. It was perfect center contact.
Matt331
Jul 26, 2015 09:40 PM
Ketis
Jul 23, 2015 12:37 PM
EscaTruck
Jul 20, 2015 11:42 AM
alex226
Jul 16, 2015 10:55 AM
Aboss
Jul 9, 2015 10:28 AM
