MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
bedside pass of assassin bars in action
Old May 13, 2012 | 10:01 PM
chevrolade's Avatar
very nice and yes install sucks on the 08+
Old May 14, 2012 | 04:38 AM
schino's Avatar
Originally Posted by Karlen
Same camera I have and I get the same vibration noise yours does. I'm going to order an external mic to hopefully get that figured out.
now that you mention that, one time i had it inside without the external mic plugged in and it did it also. the problem with the mic is the wire is not very long, if i mount it on the side like that im not sure where to even put the mic??
Old May 14, 2012 | 04:43 AM
schino's Avatar
i had myself so screwed up on install.. i knew i had to mill the axle bracket slots longer but held off because i had to cut my u bolts off and wanted to use the new ones to make sure i was right so i went ahead and put the front brackets on. once i got the new u bolts i put the axle brackets in but on my flip kit, maybe yours also, the axle is slid back on the spring so i had to also move the locating hole forward. this in turn made the bar too short. I just drilled another hole in the front bracket rather then trying to drill another hole in the spring to move it back some. im really happy with them though and for whatever reason people seem to like them a lot haha
Old May 14, 2012 | 01:26 PM
Karlen's Avatar
Just stick it to the camera, probably what I'll do with it.
Avalanche2002
Nov 30, 2015 07:31 AM
Alco
Oct 4, 2015 06:58 AM
BlownHD
Oct 3, 2015 12:24 PM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
