MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
11.5cr Eagle 408 Trex
Old Jul 12, 2007 | 07:10 PM
Quik's Avatar
5 year bitches!
Default 11.5cr Eagle 408 Trex
http://videos.streetfire.net/video/e...6901496854.htm
This is a 11.5cr Eagle internal'd 408. it has stage 2 livernois LS6 heads, thunder racing Trex [242/248 608/612 110lsa], LS6 intake, Carr performance Ported TB, LS7 lifters, SLP underdrive pulley, Pacesetter LTs, ORY with SLP loudmouth, SVO 42# injectors, ported LS6 oil pump, 7.4 hardned PRs, 85mm air lid,Spohn solid motor mounts, Tuned in SD by myself, I also assmebled the motor including the bottomend. The owner of the car Talin helped a good bit with the install. All parts were gatherd by the following companys. Texas speed, JJsAutomotive,West Coast cylinder heads, and alot of misc. items were gatherd by friends and stuff i had around
Old Jul 12, 2007 | 07:16 PM
Phantom's Avatar
11 Second Club
good job sounds good
Old Jul 12, 2007 | 07:45 PM
03sierraslt's Avatar
Sounds mean, I need to cam mine...... haha
Old Jul 12, 2007 | 07:48 PM
Quik's Avatar
5 year bitches!
the size of the motor actually tamed that cam down some. when it was in the 6.0 it was alot more lopeier at a higher rpm
Old Jul 12, 2007 | 08:55 PM
Tootall's Avatar
sounds great, how does it run?
Old Jul 12, 2007 | 09:10 PM
Quik's Avatar
5 year bitches!
have no idea, that was 2nd fire up, i still need to bleed the clutch, bleed brakes, get car inspected, he needs to get it registerd, we need to finish the interior, adjust the pinion angle if needed to be, buff/detail it and troubleshoot the charging bug we have. hopefully be ned of next week the owner will have the car at his house for the first time in a long time. the car has been torn down since early april. owner probably had the car a total of
2-3 weeks since the 6.0 was put in and that was back in late december. ive had it. so the owner has his hands full with this car and i know he'll be happy when he does drive it.
rest of car consists of T56, ram VDS clutch, moser 12 bolt with 456 gears and full suspension minus springs and shocks. has upgraded brakes on it from a vette with slotted rotors. its a heavy car with full weight and then some. the subframes are from a autocross car which makes this car nice and sturdy when driving. he wanted a quick street car, his goal for ET is low 11s/high 10s at full weight
Old Jul 12, 2007 | 09:21 PM
Quik's Avatar
5 year bitches!
heres the first fire up of the motor
http://videos.streetfire.net/video/1...6901597559.htm
simman22
Jan 21, 2017 10:27 PM
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 04:22 PM
11MPG
Sep 10, 2015 08:34 PM
