Pioneer Premier DEH-P860MP
Its about a year old and I just ordered a new HU. Im looking to get $250+ Shipping for it. Its still in my truck right now and I will be taking it out when my new one comes in. Should be about 10 to 12 days when it comes it.
Here are the specs on it. Works fine. Nothing wrong with it I just wanted the new Pioneer with the Bluetooth built in.
Product Type Radio / CD / MP3 player
Recommended Use Car
Form Factor Full-DIN - in-dash unit
Width 7 in
Depth 6.2 in
Height 2 in
Weight 3.5 lbs
Faceplate Type Detachable
Audio System:
System Control Bus IP-Bus
Sound Output Mode Stereo
Sound Effects BBE
Equalizer Yes
Controls Volume, fader, balance, loudness, attenuate
Max Output Power / Channel Qty 50 Watts x 4
Continuous Power / Channel Qty 22 Watts x 4
Crossover 2-way active crossover
Low Pass Frequencies 125 Hz, 160 Hz, 200 Hz, 63 Hz, 50 Hz, 80 Hz, 100 Hz
High Pass Frequencies 125 Hz, 160 Hz, 200 Hz, 63 Hz, 50 Hz, 80 Hz, 100 Hz
Amplifier Output Details 22 Watt - 4 Ohm - 50 - 15000 Hz - THD 5% - 14.4V DC - 4 channel(s)
Built-in Display OLED
Multicolor Display Yes
CD Changer Control Yes
Clock Yes (digital)
Additional Features Screen saver, motorized front panel, CD Text capable, satellite radio tuner control, auto volume adjustment, TV tuner control, auto equalizer adjustment, ID3 tags support, auto sound calibration
Equalizer:
Equalizer Type Digital graphic
Equalizer Band Qty 13 bands
Equalizer Center Frequencies 50 Hz, 80 Hz, 125 Hz, 200 Hz, 315 Hz, 500 Hz, 800 Hz, 1250 Hz, 2000 Hz, 3150 Hz, 5000 Hz, 8000 Hz, 12500 Hz
Equalizer Boost/Cut Range ± 12 dB
Equalizer Factory Presets Natural, Powerful, Super Bass, Custom, Vocal, Flat
Equalizer Factory Preset Qty 5
Equalizer User Preset Qty 2
Radio:
Type Radio tuner - AM/FM
Tuning Display OLED display
Preset Station Qty 24 preset stations
AM Preset Station Qty 6 preset stations
FM Preset Station Qty 18
Response Bandwidth 30 - 15000 Hz
Signal-To-Noise Ratio 75 dB
Additional Features Best stations memory
CD System:
Type CD / MP3 player
In-dash Unit Capacity 1 CD
Media Load Type Slot-load
Playback Modes Intro scan, random play, one track repeat
Supported Digital Audio Standards WAV, WMA, MP3
Response Bandwidth 5 - 20000 Hz
Signal-To-Noise Ratio 99 dB
Dynamic Range 95 dB
CD-R Compatible Yes
CD-RW Compatible Yes
Recommended Use Car
Width 7 in
Depth 6.2 in
Height 2 in
Weight 3.5 lbs
Audio System:
Sound Effects BBE
Equalizer Yes
Clock Yes (digital)
Equalizer:
Radio:
CD System:
Dynamic Range 95 dB
CD-R Compatible Yes
Add 100 and you got a deal. This is about what they are going for on ebay.
I have seen them in the past week for 350 and 375. This is a nice radio w/ no scratches and everything works great.
jtphelps289
Sep 1, 2015 09:11 PM
