Miscellaneous Classifieds Anything not vehicle specific
FS: Skil 7.2v Lithium Ion Ratchet
Old Apr 6, 2008 | 08:23 PM
explorer5.0's Avatar
TOTM: November '07
Default FS: Skil 7.2v Lithium Ion Ratchet
I have an extra 7.2v Lithium Ion power ratchet that is new in box. I bought two to use for work to unbolt equipment cabinets from the floor, but it turns out one will last all day on a charge. So, I need to get rid of the second one. It operates similar to an air ratchet- you can use it as a manual ratchet to break bolts loose, the pull the trigger to take them out. The battery is built in, and it has a wall mountable cradle/charger. These were originally $60, but I am asking $50 shipped. OR I will trade for a lithium 7.2v power driver
http://www.skiltools.com/en/AllTools...-01&cid=192170
http://www.homedepot.com/webapp/wcs/...d&ddkey=Search
Old Apr 9, 2008 | 09:17 PM
TOTM: November '07
I know someone wants this thing- it would making putting parts on go so much faster
Old Apr 11, 2008 | 12:57 PM
Red04Silverado's Avatar
I have one of these, great tool to have! Bump
Old Apr 11, 2008 | 05:44 PM
ZZebes's Avatar
How much oomph do these have
Old Apr 11, 2008 | 08:18 PM
TOTM: November '07
It isnt going to loosen main caps or anything, but it did take 3/4 head lag bolts out of the floors (plywood) of my equipment shelters without problems. It will turn bolts you cant turn with your fingers But since it works like a regular ratchet, you can break bolts loose manually, then power them out (just remember, its only 1/4" drive). You can also use it as a right angle screwdriver.
dropkick13
Feb 22, 2008 04:47 PM
Fellow294
Oct 5, 2006 09:27 PM
Fellow294
Aug 18, 2006 03:41 PM
