Miscellaneous Classifieds Anything not vehicle specific
Brut pressure fed sandblaster Model 101H
Old Feb 13, 2016 | 06:17 PM
ALL ULL C's Avatar
Default Brut pressure fed sandblaster Model 101H
Well since I only used this once 8 years ago and it's been sitting in the corner of the garage ever since that it is time to see if anyone else can find a better use. This thing worked flawlessly and I only put about 400lbs worth of baking soda through it in a day and that was it. All ball valves move/operate freely, I will be replacing the pet **** valve and the relief valve is froze so that will be replaced as well. Just the minor surface rust you see since the fittings are mild steel and the coating has come off over the years. The vessel itself has had some coating flaking as well in areas. The hose is is great shape with no outer wear or abrasions. Three extra tips included (one 1/8" and two 1/4") and the blasting hood.
Same model retails today still for $560
https://www.brutmfg.com/sand-blastin...er-101h-detail
Asking $old
If it needs to be shipped I would estimate somewhere in the $50-75 range as I could get it in some type of box with it only weighing 60lbs. I have the ability to have this shipped freight too if it ends up being cheaper.
Old Feb 16, 2016 | 01:10 PM
arthursc2's Avatar
Did you use it to blast a car with?
What size compressor did you use to feed it?
Old Feb 18, 2016 | 09:29 PM
ALL ULL C's Avatar
No I used it for cleaning up interior brick walls to paint/coat.
I used a pull behind compressor (185cfm/150psi) which was excessive but I never had air problems.
This is SOLD
13chevy370
Nov 18, 2016 06:22 PM
gallo-lo
Feb 19, 2016 06:46 AM
06 4.8
Feb 13, 2016 04:25 PM
YAMAHAGUY
Feb 12, 2016 06:51 PM
Raiderjim
Feb 11, 2016 10:34 PM
