Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Transmission Problem
Old Mar 14, 2016 | 12:04 AM
07ghost956's Avatar
Registered User
Unhappy Transmission Problem
Got this 2007 5.3 single cab silverado just got this truck and it has being sitting down for some months before i bought it the truck was running fine than after a week of driving trans fluid was gone..can this be a leak? truck revs to way much before going to second gear and on
Old Mar 14, 2016 | 12:15 AM
FFDP's Avatar
Let me ask you this question.
If the transmission is designed to hold a certain amount of fluid and that level drops, how else besides a leak is this going to happen??
Not trying to make you sound dumb but just think that through a little. It's time to get under the truck and see what is going on. Fill it back up to proper level and start checking things over. Just know that you may have damaged this transmission because you ran it low on fluid and is now slipping.
Old Mar 14, 2016 | 12:33 AM
07ghost956's Avatar
Registered User
Thanks bro i have a looked at it..sorry im new to this truck stuff.
Old Mar 14, 2016 | 10:37 AM
07ghost956's Avatar
Registered User
Ok I already check for leaks it don't have any drive way clean and bottom of truck too went under and everything looks clean
Old Mar 16, 2016 | 06:37 AM
NJmooch's Avatar
Did you check the trans fluid level when you bought the truck? It may have been low to start with. It may have taken a week of driving before parts started to break down from lack of fluid. This would be a bad situation. Once the fluid level is fixed, check to see if the slippage goes away. If it does you lucked out, but there still might be some internal damage to the transmission. Keep us posted.
jtphelps289
Mar 21, 2016 11:16 AM
MXDAD140
17
Mar 6, 2016 11:19 AM
Lbzduramax
Mar 4, 2016 06:53 AM
Jeremy Cookie Cook
Feb 17, 2016 08:40 PM
dimetweaker
Feb 16, 2016 07:23 AM
