Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Picked up my LQ4, first part to my build
Old 02-14-2013, 08:41 PM
  #21
LsXblaze's Avatar
Okay so... i ordered mahle piston kit through summit this morning... those guys are awesome they price matched so i got an awesome deal. i will soon be ordering all clevite bearings. and now im curious on the main cap bolts... can i used stock main bolts with my build? dont plan on taking apart the bottom end. will be using arp rod bolt for sure tho
Old 02-22-2013, 01:11 AM
  #22
LsXblaze's Avatar
Pistons came in today! Ordered all the bearings today from summit... all i need to get is rod bolts and main bolts and off to the shop we go...
Attached Thumbnails Picked up my LQ4, first part to my build-20130222_003437_resized.jpg   Picked up my LQ4, first part to my build-20130222_004449_resized.jpg
Old 02-22-2013, 11:57 PM
  #23
Gonoma's Avatar
Are you asking if you can reuse your old main bolts?
Old 02-23-2013, 07:55 PM
  #24
LsXblaze's Avatar
new oem bolts??? im thinking bout going with new oem rod and main bolts.... its going to be a N/A motor wont rev past 62 -6300rpms between 10 and 10.5 to 1 comp
Old 02-23-2013, 08:40 PM
  #25
Bowtie502's Avatar
Arp..
Old 02-24-2013, 09:26 AM
  #26
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
Originally Posted by Bowtie502
Arp..
Agreed! On the rod bolts I would run the ARP bolts 100% but on the mains I would prob do stock bolts to save money.
Old 02-25-2013, 12:26 AM
  #27
LsXblaze's Avatar
arp rod bolts has been my dilema.... from what i have read is that when just changing bolts out and putting arp inplace of oem there seems to be no problems... but if its a complete rebuild there seems to be some hesitation..im just worried about the arp's putting too much clamping force on the cracked cap design rods... any insight on this or should i not be worried
Old 02-25-2013, 01:05 AM
  #28
11 Second Hall Moniter
AKlowriderZ71's Avatar
What power level is your goal? Are you using any power adders? Stock bolts in the bottom end are good for quite a bit.
If you decide on ARP rod bolts, or ARP mains, I'd recommend you have your machine shop check to see if any resizing or align-honing is necessary. Seems like there's more possibility of "distorting" the bearing journals with the ARP's.
Old 02-25-2013, 10:48 AM
  #29
LsXblaze's Avatar
im shooting for 350 to the wheels. anything over 300 and id be happy. strictly N/A i just want it to be a fun dd and take it to the strip a couple times a year
Old 02-25-2013, 02:29 PM
  #30
I'd just run the stock main & rod bolts.
Quick Reply: Picked up my LQ4, first part to my build
