Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
8.1 in colorado?
Old Jan 14, 2012 | 07:46 PM
corv271's Avatar
Default 8.1 in colorado?
A friend of mine has an 04 colorado with the 3.5. He wants to do a v8 swap eventually and when I mentioned the gen VII 8.1/allison trans he got all wide eyed lol so I was just wondering if it would be possible to do this swap? what all will I need? Can the stock rear axle handle it?
Old Jan 14, 2012 | 08:21 PM
skinny chicken's Avatar
That engine and tranny is way to heavy to be practial in that truck. Just do a 5.3 and 4l60 swap. Its much easier and would be a hoot to drive. Thats just my 2 cents
Old Jan 14, 2012 | 08:30 PM
corv271's Avatar
Skinny, what do you mean by practical? thanks for your opinion =)
Old Jan 14, 2012 | 09:11 PM
Custom headers for the 8.1 would be high dollar. That allison trans would drag the ground without doing major tunnel work. You can make alot of power with a 6.0 or 5.3 for reasonable cost. The 8.1 doesn't have a big aftermarket following. Heads cams intakes ect
Old Jan 14, 2012 | 09:25 PM
corv271's Avatar
ok, Thank you for explaining that. The trans dragging is definitely a huge issue. would a 4l80e be a better option? I think they used that trans in the avalanche 2500s
Old Jan 15, 2012 | 12:01 AM
bighoss77's Avatar
cost wise a 5.3 or 6.0 swap would be alot better, and 285-325hp in a colorado is more than plenty.
Old Jan 15, 2012 | 12:08 AM
Just what he said^^^^
The 4l80 is a beast to, Its alot bigger than the 4l60. Go with a built 4l60 with a 400hp motor and it will be nasty.(auto colorados come with 4l60)
Im building a colorado with a 5.3, 4l60, and a big nos bottle lol
I will be starting mine in a few months so ive done a ton of reaserch. Mine will be used as my DD so im going to stupid so I can keep reliabilty.
Old Jan 16, 2012 | 03:37 PM
05_quick4door's Avatar
The i5 performs well with boost if he just wants a nice jump in power
Old Jan 16, 2012 | 05:19 PM
Team Paulie's Avatar
Registered User
Big block sounds cool,but not to practical when you can do a LS1 or any of the truck V8's and weigh a whole lot less and get just as much power.
Old Jan 17, 2012 | 09:55 PM
1FastBrick's Avatar
Custm2500's Rude Friend
He may have to do an axle swap. I am not sure what rear end the colorado uses but If it's smaller then the one in the 1500 silverado's which is refered to as the 8.5/8.6.
I dont know for sure but some of the info I found says it may have an 8.0 ring gear.
