Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
1988 s10 blazer injector prob
Old Jun 25, 2009 | 09:11 PM
JoeGibbSilverado's Avatar
Default 1988 s10 blazer injector prob
My brother recently purchased a 88 s10 blazer with the 2.8, problem is, he gets gas to the injectors, but they wont spray, u can manually hotwire and ground the injector, and it will spray like crazy, checked the relays, and fuses, all good. any ideas? thanks
Old Jun 25, 2009 | 09:56 PM
CODE4LS1's Avatar
May want to check the PCM.....may be a bad one.
Old Sep 22, 2009 | 12:30 PM
Use a noid light to check for injector pulses. It is possible the ignition module quit, it sends a synch signal to the pcm that it has to see before it will enable the inector driver outputs.
Old Sep 22, 2009 | 12:31 PM
Need to check for spark first and make sure it has it. If not you could have a ignition module or pickup coil in the distributor giving trouble.
OHsixLS3
Sep 25, 2015 11:20 AM
Go5.3tt06
Sep 24, 2015 08:12 PM
jroctpb
Sep 16, 2015 09:05 PM
Sdailey
Sep 6, 2015 10:26 PM
