Member made Tools & Parts Classifieds Need permission to sell in this section...see section guidelines
Disk Brake Brackets for 15” Wheel Conversion
Old 04-17-2015, 07:43 PM
  #71
iamkeniff's Avatar
The rotors look small in a 22" wheel
This was installed on my 2008 gmc sierra. 10 bolt rear end that is narrowed 3" each side for a total of 6". Custom Moser axles.
iamkeniff is offline
Old 04-17-2015, 08:11 PM
  #72
GMCtrk's Avatar
I see you also got the midget studs from Moser.
GMCtrk is offline
Old 04-17-2015, 08:37 PM
  #73
iamkeniff's Avatar
He said thats the longest that they offer
If i have to i'll swap to my oem studs
Old 04-17-2015, 08:55 PM
  #74
GMCtrk's Avatar
Are your billets hubcentric? With a hubcentric wheel the shorter studs aren't a huge issue, but with lug centric wheels like my 15s, it's a giant PITA getting everything centered and the lugnuts on with the midget studs. I would have rather had long 1/2" studs than midget 14mm studs, even if the later is minimally stronger. My axles are actually dual drilled from Moser, so technically I could remove the 14mm studs and change to 1/2
GMCtrk is offline
Old 04-17-2015, 09:47 PM
  #75
iamkeniff's Avatar
Hub centric i think
Old 05-02-2015, 11:19 AM
  #76
iamkeniff's Avatar
Mine has weld on leaf perches, but it'd be the same as a flip kit. So a gmt900 truck with a flip kit AND NARROWED REAR END will need to remove the u bolts to install the caliper with this kit
Old 05-02-2015, 12:25 PM
  #77
GMCtrk's Avatar
Been running these brackets for a while without any issues, awesome product.
The one thing I would like to see come with this as a kit would be a bracket to hold the brake line.
GMCtrk is offline
Old 05-02-2015, 12:50 PM
  #78
iamkeniff's Avatar
How is yours setup gmctrk? After i get mine cut, flared and installed i'll post up
Old 05-02-2015, 02:08 PM
  #79
GMCtrk's Avatar
Well, I didn't have any issues with the calipers and the flip kit like you're posting. And now my axle is unflipped (raised to stock height) also with no issues.
I'm using the Russell SS lines and they are bolton with the calipers, although a tad redundant.
GMCtrk is offline
Old 05-02-2015, 10:09 PM
  #80
iamkeniff's Avatar
I have a narrowed rear end that's why i had the issue
Quick Reply: Disk Brake Brackets for 15” Wheel Conversion
