Harley Mod Help
Looking to get 8lb pulley , cone filter&tube , and programmer(sct,predator)will this be safe whats good mods Thanks for the help
8 lbs is okay. You're only running 6 psi stock, so you'll be looking at a total of 14 psi max, maybe 15 on a cold day. Personally, I'd go with the SCT to start with, then a dyno tune to make sure your air/fuel ratio is spot on.
Welcome to the site. Nice to have more guys showin up. |
thanks for the info
the way i understand it is that an8lb would only be 6lbs on the HD because of the diff on the upper btween the HD and the L. I was going to get the tuner and the pulley same time install and the guy im getting from was going to do tune (custom)when he came in town in april |
Originally Posted by BK_03HD
thanks for the info
