Cam install???
Old 04-26-2008, 10:05 PM
Default Cam install???
Ok so i'm going to order a cam for a 02 lightning. What is the max lift on the stock springs??? The specs of the cam are 233/237 @ .050 Duration .545"/.550" Lift 113 LSA. It's an LFP custom grind cam. Does anyone run there cams??
Thanks,
Brad
Old 04-28-2008, 08:19 PM
203Cree's Avatar
Thanks,
Brad
Way over what the stock springs will handle. Comp and Crower both make springs that will take up to .600...... look into a set. Good luck with the swap!
Old 05-14-2008, 01:10 PM
steeltoe's Avatar
you also need to buy the mustang cam gear, gear bolts, spacers, and washers. most of the aftermarket cams are on romeo blanks which have bolt on cam gears. where the L uses windsor motors which have press on cam gear
Old 06-22-2009, 08:12 PM
Registered User
outlaw351's Avatar
yep i did the same thing
all_individual
10-10-2015 10:09 PM
low2001gmc
07-23-2015 05:10 PM
Offroadunleashed
07-20-2015 02:25 PM
ssierra08
07-15-2015 06:40 AM
all_individual
07-13-2015 11:01 AM
Quick Reply: Cam install???
