03 Harley Davidson supercharged truck
If it were mine I'd just put a 6lb lower on it, change the plugs, get a tune, valve body, and cut the bottom out of the stock air box and drop in a K&N. This will provide you with all the power you'll ever get without big (pricey) bolt-ons, changing the blower, or going internal.
TOTM: January 2007
Originally Posted by 03BlownHarley
I have the same truck and run low 13's. I have minor bult ons plus a more aggressive tune. heres the list: First was the k&n free flow intake and following that was the pulley swap to up the boost to 8lbs. Then i took it to the local ford dealership with and svt specialist on staff and had it tuned like a lightning. following this was magnaflow exhaust and high flow cats with jba shorties. To top it all of there was a little trans work and 4.10 gears in the rear. I also threw some lowering shackles on the back to drop the *** two inches so it sits level. I think with a new tune and a head swap i could get down in the high 11's or low 12's. All of this was done for around 8,000$.
Just some thoughts...
for 8k, you could have done a KB, nessecary fuel upgrades, tune, built tranny with stall and had a low low 12 second ride
03, davidson, forum, harley, motor, performance, plugs, pulley, shift, stick, supercharged, supercharger, swap, truck, turck
