Yet Another LSX Build Up
Old Oct 18, 2007 | 08:45 AM
zippy's Avatar
I remember hearing something about this build up. I agree that the 65E is going to be challenged for sure. If the 10 bolt gives up, the 14 bolt should be a direct bolt in anyway from one of the new Av's with the L76. I think the compression is fine, if anything a bit low. He just needs to keep the blower off of it.
Old Oct 18, 2007 | 10:00 PM
supersub's Avatar
Originally Posted by TurboBerserker
Cam is pretty extreme in the lift department -- you will need some pretty serious fly cuts (unless the L92 angles fix that PV clearance issue -- I don't know). You should probably be closer to a 117.5 on the lsa -- what you have has a decent bit of overlap to it (you want 0 for boosted motors), but I like the duration. It might be a little too much split, but your combo wants a good split -- I'd have suggested a 10 or 12* split, and you're at 13
cam card shows 227/239 639/649 on 114 with 5* overlap.
Old Oct 18, 2007 | 10:06 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That's cool -- 5* isn't too bad. What lobe profile? Can you post the whole cam card info?
Old Oct 18, 2007 | 10:17 PM
supersub's Avatar
Here is some more info:
OPENING CLOSING
IN -0.5 BTDC 47.5 ABDC
EX 53.5 BBDC 5.5 ATDC TOTAL OVERLAP 5.0
114 CENTERLINE
supersub's Avatar
ooops! LSK
Old Oct 18, 2007 | 10:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Compression seems a bit high, can you lower it any? Less compression and more boost is safer like has already been stated.
I AM A MOTHERF*CKER
OPENING CLOSING
114 CENTERLINE
You are in like Flynn man. What lobes are those? They break my lsa guesstimation rule of thumb
ooops! LSK
Ah -- LSKs Holy simultaneous posting batman!
Old Oct 18, 2007 | 10:24 PM
supersub's Avatar
Heads are not done yet so 75 cc there.Have .040 cometic's so could go .051
stock ls7 there.So mid 10's could be possible.
pistons are manley -5 cc But they have been cut for both 12* and 15* valve angle and was told -7cc total.
And I just had them coated.($$$$)
Old Oct 18, 2007 | 10:25 PM
I AM A MOTHERF*CKER
Sounds like you're going to be having a lot of fun in the near future.
Solid build -- seems well researched, and a good package.
Old Oct 18, 2007 | 10:31 PM
supersub's Avatar
KOOOL! Thanks for up and up.
Still a few stress pionts out there.
Me personally Big one "PORT VELOCITY" Is it there?
cruise RPM Will it buck or purr? We CRuise up here @ around 75-80
It's like cup racing around here.
