Yella Terra Rocker Arms
I have used them on a few builds. They are very nice rockers for sure. They come with new extra-thick valve cover gaskets, and spacers for the bolts, so they will fit under your stock valve covers. If you buy them used & don't receive those items, you'll need to buy them from YT, or figure out how to make them.
I have used Yella Terra rocker arms on a bunch of builds on several different applications. Big block chevy small block, ls1, ls3 and ls7. I have never had any issues with them. Of course when I plan a build, I use a combination of parts that will work together. Also, Yella Terra has different models for different applications to match with cams and spring combos. Not a lot of people know that they have the ultralites for the light build, Yella Terras and the Platinum series for the high spring pressures on the more serious builds.
