Which would produce more towing power?
Old Sep 30, 2007 | 06:26 PM
  #21
VINCE's Avatar
Shorty Director
Originally Posted by moregrip
what are you trying to pull?
Magnuson has a very nice tow setup for the LQ4
Well I am not trying to pull anything in particular, but I want to maximize my chances of not having to struggle towing what a stock diesel can tow. I think I read a stock diesel can pull something around 23000lbs. My current gas truck I think can pull a little less than half that..
Old Sep 30, 2007 | 07:32 PM
  #22
Leroy_454's Avatar
I would probably just get a Radix without too much thought. I tow with a 2500HD 6.0L very heavy and I usually have to pull in 3rd gear, but this is more weight than average im talking. (up to around 12000lbs. cargo on the trailer, not even counting truck and gooseneck trailer) With a heavy truck like yours I think the radix would be in boost at a much lower throttle position than others see. I'm curious how a turbo kit with a properly sized turbo and safe tune would perform. You could roll into boost gradually.
Old Sep 30, 2007 | 07:54 PM
  #23
VINCE's Avatar
Shorty Director
Leaning toward Radix and cam at this point. I wish I can find someone that has this very setup so I can take it for a ride..
Old Sep 30, 2007 | 09:46 PM
  #24
BlownChevy's Avatar
blownerator
25 Year Member
Interesting dyno graphs for those that think a 408 makes more tourqe down low compared to a Radix 5.3:
I will take the 450 ft pounds at 2400 rpm
Old Sep 30, 2007 | 09:50 PM
  #25
BlownChevy's Avatar
blownerator
25 Year Member
and another post:
Originally Posted by j's01silverado
Completed the 90mm conversion dynoed. Only change was TB, j-tube, and tuning. I did not gain boost like most have experienced, actually lost about 1/2 psi. Peak hp gain was exactly 30rwhp and 24rwtq.
Now I need to get to the track and get some numbers. I think this should be good for a .1-.2 in good weather.
Old Sep 30, 2007 | 10:18 PM
  #26
parish8's Avatar
single digit dreamer
there is no need for a bypass valve switch. the system works as is and is completely transparent, like brian said before you reach 0 vacume the valve is closed. as the load comes on the boost goes up. more load = more boost even if the rpm doesn't change.
it really is a dream to tow with a radix(whipple in my case). i could hit 3 psi in the driveway just my punching the gas pedal quick.
Old Oct 1, 2007 | 04:51 PM
  #27
VINCE's Avatar
Shorty Director
Very interesting!!
Oobray
Jun 13, 2022 03:38 AM
Zizzle
Oct 19, 2017 08:44 PM
2500ZL1
Jan 25, 2016 06:30 AM
Y2KLimited
Dec 5, 2015 09:57 AM
atxlt
Jul 20, 2015 11:06 PM
