Will this design roller rocker fit a 2005 5.3L ??
Old May 30, 2013 | 12:09 AM
1logote's Avatar
Default Will this design roller rocker fit a 2005 5.3L ??
Can anyone say for sure if these will bolt directly onto a 5.3 liter engine? Thank you for your help. I tried searching some and didnt find anything definitive, so new thread.
LS1 LS2 LS6 Stainless Steel Roller Rocker Arms Adjustable w Hardware Chevy 1 8 | eBay
Old May 30, 2013 | 12:14 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I can't speak for the quality of the product, but yes. That is the correct application according to the seller's listing.
Old May 30, 2013 | 12:59 AM
TexasGMC08's Avatar
What are you thinking the reason they wont work???
Old May 30, 2013 | 01:28 AM
oakley6575's Avatar
This... But I would be scared to run them.
Old May 30, 2013 | 06:22 AM
Gadgetized's Avatar
I run comp roller rockers. If I had to do it overagain I would have just used the stock rockers with the trunion upgrade. I actually almost switched back when I did my latest engine. I bought the trunion upgrade, and installed them in the rockers. I changed my mind at the last minute just because I had them.
Old Jun 9, 2013 | 11:49 PM
1logote's Avatar
I just wasnt sure if the rocker system on ls1 heads are the same as what comes on the 5.3 heads. Any reason why they may not be trust worthy?
Old Jun 14, 2013 | 07:53 PM
Blackpanther99's Avatar
Yes it will.
Old Jun 14, 2013 | 10:33 PM
jerryls7's Avatar
any updates on this rocker..
Old Jun 15, 2013 | 12:56 AM
ls6musclehead's Avatar
I ran the Ebay sold pro comp non adjustable aluminum rockers in a 1.8 ratio and stock valve covers and I had to clearance the VC in a number of places to keep them from hitting. Those have adjuster screws that are significantly taller than the aluminum bodied rockers I got. I think you will need taller valve covers.
Old Jul 9, 2013 | 11:01 PM
1logote's Avatar
Ahh thanks for that info. Spacers or new covers def add to the complexity some and the expense. I think I will just wait
