Whats a set of stock 317s worth
Old Jul 2, 2010 | 09:30 PM
fastrt's Avatar
11 Second Truck Club
shipping is high! try to get at least $100 plus shipping. if you ask too much they will sit there.
Old Jul 5, 2010 | 05:40 AM
Yukonjackgt's Avatar
Thanks guys , I wasn't sure. Not lookin to make a lot just get em out of the way and didn't want to ask stupid money and have em sit around forever.
Old Jul 10, 2010 | 01:20 AM
ByuTrukr's Avatar
formerly ByuTrukFreak
What are 317's for?
Old Jul 10, 2010 | 01:53 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by ByuTrukFreak
What are 317's for?
Original equipment on 6.0's...
Old Jul 10, 2010 | 11:25 PM
ByuTrukr's Avatar
Thanx, i found the sticky on that after I asked the question
Old Jul 11, 2010 | 01:17 AM
budhayes3's Avatar
PT's Slowest Truck
Right on BTW, the 99-00 6.0's are different and came with iron heads, and also had a longer crank that won't mate up to a 60/65E. Not sure of the casting numbers for those heads, but they're the only iron LS heads that I'm aware of.
Old Jul 11, 2010 | 02:34 AM
ChevyTruck's Avatar
something else
Casting Number 873
Head: 1999-2000 LQ4 6.0 Liter Truck
Material: ***Cast Iron***
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Compression Ratio: 9.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Material: Aluminimum
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Stock Head Flow Numbers
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
What you need to know:
The LQ4 head received aluminum heads starting in models year 2001. All other features are the same as previous years iron heads. This is the workhorse head for street / strip turbo and blower cars. They offer a large combustion chamber that lowers compression ratio making them perfect for a forced induction application. Swapping on the LQ4 head drops the compression ratio of a typical LS1 engine to 9:5.1
The Cast-iron casting are heavy!
There is some more info on the two different types of heads.
GrooveCityZ71
Aug 31, 2015 12:05 PM
sauldgold
Jul 23, 2015 02:15 PM
Ketis
Jul 23, 2015 12:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
gavin2005
Jul 16, 2015 12:09 AM
