What's the least path of resistance?
Old Dec 3, 2013 | 06:19 PM
BadAsseryPhD's Avatar
Default What's the least path of resistance?
I got a bitch of of a broken header bolt on the driver's side, closest to the fire wall, where there is no room to work with. I have tried right hand bits, left hand bits, extractors, etc to no avail... the results I had was... using a right angke attachment on my drill was I made a deep enough hole to put in an ease out... I broke the ease out off in the hole I made in the broken header bolt, started all over and now its like I can't makr any headway drilling this bolt out... I drill till my arns give out or I run out of beer and patience. I'm at my whits end... please help. Should I pull engine or heads to have more room or just bow out and take to a shop?
Old Dec 3, 2013 | 06:23 PM
whitedakota's Avatar
Mines been broke for a few years now... I have cal speed headers on for 2 years with no leaks. I used high temp copper rtv both sides of the factory gaskets. No leaks!
Old Dec 3, 2013 | 06:24 PM
We tried welding a nut to it but it didn't work so we just left it!
Old Dec 3, 2013 | 07:18 PM
Chevy_King1500's Avatar
buy yourself a nice set of heads for Christmas.
Problem solved
Old Dec 3, 2013 | 08:22 PM
68haywagon's Avatar
Dorman Products - 917-107
Old Dec 3, 2013 | 09:23 PM
Dangeruss5.3's Avatar
I usually weld something to it and back it out. If not just pull the head. Pretty easy to do and a machine shop can have it out in no time!
Old Dec 3, 2013 | 09:57 PM
AUTOT3K's Avatar
the e-z out is stronger then the dril bit your using thats why its not working anymore, pretty well at this point your only option is to take the head to a machine shop and let them work they're magic
I get this at work quite often and the customer is always warned...there's always that other option...
luckily I havent had one break yet
Old Dec 3, 2013 | 09:59 PM
grey matter 04's Avatar
13 Second Truck Club
Originally Posted by 68haywagon
Damn that's neat I had to make one like that years ago.
Old Dec 4, 2013 | 04:56 PM
RezinTexas's Avatar
get some of these when you finally get the old bolt out
ARP Header Studs
Old Dec 4, 2013 | 05:04 PM
Vortec350ss's Avatar
One missing bolt on your headers won't create a problem... just run that bitch! It'll be fine!
I do agree with the header studs though for next time! I need to get some of those myself.
