What pistons do I have?
Crap so I'm still confused on the pistone I have. I don't want to have the wrong mill if I have a certain piston if that makes sense. Don't want to leave the truck down longer than I have to if the heads aren't cut right. I will be running a method system so wouldn't I want in the 9.5 to 10.0 cr range?
65cc chambers will be in the 9:1 compression range.
No around 64-65cc on all 243/799 castings.[/QUOTE]
But he said they were milled 24thou... And they are worked from LME, so really the CC could be any size? But a stock cc 799/243 milled 24thou should be in the 59-60cc range.... As long as LME didn't work the stock combustion chambers
ehhhh, it's really just getting the compression ratio you want... That's why people use factory 317 heads to get the compression down some on factory motors, 317's are 72cc... And they flow just as well as 243/799 heads, but with larger combustion chambers. The diamond Pistons I just purchased will be around 9:1 with a 317 head and around 9.6:1 with 243/799 heads, which is what I'll be using.
The pistons looked awful in it too.... they were all pitted on the face... like the surface of the moon. I get to see some strange things from the depths of my buddies engine shop lol. The cheap *** owner had him hone the scored cylinder ( it still didn't clean up) after he had the heads redone, put on new rings and he put it together himself at home. Then had a hell of a time getting the afm solenoids or VLOM because he didn't want to pay for it.... some peoples children. It's got a gen iv 4.8 cam in it because he took that from me.... oh well lol.
