what does burnt valves sound like?
Old Aug 30, 2006 | 11:18 PM
goshawk23's Avatar
Truck addict
Default what does burnt valves sound like?
like the question asks. what do they sound like. btw, i think i did worse but i wan't to diagnose as many problems that i may have before i go buying new stuff
Old Aug 30, 2006 | 11:33 PM
kbracing96's Avatar
The motor will have a bit of a miss to it and if you stand by the exhaust, you will hear a kind of ticking noise come out of it.
Old Aug 31, 2006 | 07:18 PM
MCDiver's Avatar
I was taught to hold a dollar bill over the exhaust (hold the short side and let it rest over the pipe, do not hold both sides). If it sucks it into the pipe, you have a problem, if it just flaps in the wind, you are in good shape (oh yeah, and don't let it go, if you have a valve problem, you just lost a dollar........... or more depending on what you used).
Old Aug 31, 2006 | 08:19 PM
thats a pretty cool little redneck diag. trick. i like it
Old Sep 1, 2006 | 10:19 AM
onebadrubi's Avatar
will a burnt valve throw any codes? What about oil consumption or anitfreeze?
Old Sep 1, 2006 | 10:37 AM
i wouldnt think that it would throw any codes, and depending on what valve it would be seems like that would justify oil consumption. if an intake valve was burnt, it wouldnt seal on the exhaust and if the exhaust was burnt, it would suck in exhaust gases on the intake stroke so i dont think it would burn oil then.... maybe you wouldnt burn oil if your valve guides are still in alright shape
Old Sep 1, 2006 | 10:58 AM
FMOS Racing's Avatar
It will really only show up as a rough idle and a very bad leakdown test.
Don't think you can burn an intake valve (at least I've never heard of one).
Old Sep 1, 2006 | 08:23 PM
02sierraz71_5.3's Avatar
If your burning antifreeze youve got alot bigger problems than valves
do have whiteish bubbles in the oil or does oil end up in the coolant reservior?
Old Sep 2, 2006 | 01:50 AM
jblack6527's Avatar
I have heard that as well. It does work.
Old Sep 2, 2006 | 02:38 PM
ScojoDak's Avatar
A compression test, leak down test (as mentioned before), or a vacuum gauge will reveal any valve sealing problems.
