vvt cam swap in gen lV 5.3
Old 01-29-2013, 12:49 PM
adam8076's Avatar
Wow thanks man, you just made this a sh ¥+ ton easier
That vinci cam is it a vvt cam ?
Do you know the max lift the gen 4s can go with stock head gasket thickness
I know these things respond well to more lift
Yeah im aiming for max torque with stock heads , at least for know its a dd and not a race truck but I do love it and cant stop moding it
Thanks for the help
Old 02-01-2013, 08:05 PM
craigsix's Avatar
im doing a cam swap in my 2012 5.3 lmg motor. im keeping the dod lifters and using blue springs from scoggin dickie. we already have #799 ls6 type heads. im running grind#689-421-13 cam with phaser limiter#5460. you will need a different timing gear if you run a three bolt cam. and you wont need a phaser limiter.
Old 02-02-2013, 12:14 AM
adam8076's Avatar
Craigsix , im glad someone else is doing this . Im not sure which cam that is bjt ill look it up When do u plan on having this beast up n running ? Goodluck man would really like to see a idle vid,.as far as all the present vvt cams available they all sound amazing
Old 02-02-2013, 03:10 PM
craigsix's Avatar
my mod list so far with 6000 miles. knn filter airraid tube ported tbfast lsxrt 102 intake slp udp kooks longtubes with kooks catted ypipe into 3 inch exhaust with 3inch 18" glasspack with turndown before axle.yella terra 1.8 shaft mount rockers. circle d 3200 converter. tuned by area47 shifting at 6100rpms.coming soon 4.10 gears and the dod/vvt cam i mentioned before!
Old 02-02-2013, 03:26 PM
craigsix's Avatar
the cam is comp camshaft gm ls 358 vvt/afm 266piihr14.part #689-421-13.specs are 216/214 intake 228/226 exhaust duration at .050 .500 lift to be safe with the dod lifters.however with my 1.8 yella terra rockers it will be about .536 lift.
Old 02-02-2013, 08:40 PM
adam8076's Avatar
Well lets hear it !!!! ; )
Ammadien
07-22-2015 08:50 PM
WICK3DxGATA
07-21-2015 06:59 PM
Suburban2500
07-19-2015 04:50 PM
06 4.8
07-15-2015 07:17 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: vvt cam swap in gen lV 5.3
