Venolia pistons
Old Jan 4, 2009 | 09:01 PM
TURBHOE's Avatar
Default Venolia pistons
anybody ever heard of these? are they any good?
Old Jan 4, 2009 | 09:08 PM
ZO6Ted's Avatar
Been around forever like wiseco, j&e, trw (speed pro). A real quality product.
Old Jan 4, 2009 | 09:27 PM
TURBHOE's Avatar
can some one help me fill out a form for some pistons and rods? i may have a chance to get a really good deal on some venolia pistons and rods. but i have to fill out the order form so the guy can see what he can hook up.
here is what i'm thinking i want. a 370 turbo friendly some where around 9:1 compression and 6.125" rods. using a set of 317 heads and stock mls gaskets. also stock 3.622 stroke crank. I'll post a link to the form. thanks in advance.
http://www.venolia.com/images/form.pdf
File Type: pdf
Old Jan 5, 2009 | 07:55 PM
ZO6Ted's Avatar
You should really let your machinist do that. That way it is on him to do it correctly.
Old Jan 5, 2009 | 09:14 PM
L7 Sierra's Avatar
Bump- you need to know for sure the amount of overbore your going to use. These new motors from the people I know tell me they usually get by with a 20 over where an old SBC would need a 30 over.
Also go with the smallest bore you can get away with. This helps keep your bore from distorting under high pressure or RPM. Plus it keeps the temperature more stable then if you go whole hog.
I did a 350 sbc years ago with a 60 overbore just becouse I could use parts from a free motor to do this. In the end the temperature swings were pretty wild from street to freeway to stuck in traffic. It would run pretty cool "160" on the freeway, and if putting through traffic it would touch "200" and thats not very good.
Old Jan 6, 2009 | 06:51 PM
TURBHOE's Avatar
was looking to just use a new block probably. i think i got it all figured out. i just looked all over the net for answers lol. at the moment its just for a quote to see if he can do it. then i will get exact measurement.
Old Jan 9, 2009 | 08:06 AM
05crew's Avatar
i have a 370 with Venolia piston in it. a real good pistons. but it will take a few weeks to make them. other pistons are in stock for our motors, but Venolia makes them to order.
Old Jan 9, 2009 | 10:47 AM
TURBHOE's Avatar
if you don't mind me asking what did you pay for them? if you want you can just pm me. Did you ask them to make a 4" ls1 piston or a lq9 piston. I talked to one of the guys there last night and they weren't sure what a lq9 or lq4 was so I ask if he'd done any ls1 pistons. He said yeah sure have. I was said ok make a 4.010" version of that. After that we were on the right track.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
