Vacume at Idle?
Old Jun 30, 2007 | 10:45 AM
Spoolin's Avatar
GFYS and STFU
Default Vacume at Idle?
What is the optimum vacume to have at idle and why is it important? I heard 10 inches of vacume is ideal for drivability but is too much vacume a bad thing?
I would assume things that would effect vacume could be cam's (+/-duration) as well as idle speed of course.
Would a lack of vacume suggest blow-by or bad rings?
Thanks
Old Jun 30, 2007 | 11:05 AM
2004SSS's Avatar
im getting more vacuum than i though i would to im sitting at almost 15 inches, but my cam is huge though.
Old Jun 30, 2007 | 11:07 AM
blown3qtr's Avatar
I believe a stock motor runs about 15 inhg at idle . My 408 runs about 10inhg. Cams definately affect manifold vacuum. Bad valves / seats could also show low vacuum. I know vacuum is one indication of the overall health of an engine (comparing stock engines of course).
*EDIT* just checked, 408 idles at about 12inhg.
BlownChevy's Avatar
blownerator
25 Year Member
10 inches is the minimum in my opinion. I think we may be chasing a vac leak someplace in your set up, we will get to the bottom of it next week when we tear into it.
Old Jun 30, 2007 | 12:40 PM
04Denali's Avatar
I am at 19 inches of vacuum at idle,
Mark
Old Jun 30, 2007 | 04:18 PM
Spoolin's Avatar
GFYS and STFU
Originally Posted by Brian@JPA
...I think we may be chasing a vac leak someplace in your set up, we will get to the bottom of it next week when we tear into it.
Thanks brian, I know you'll do your best to trace it out and find the problem.
But as for myself I didn't know why we want vacume at idle or what the benefits are. I know on my original set-up I was seeing +/- 14 inches of vacume and on my Typhoon I was seeing 18-19 inches.
Old Jun 30, 2007 | 04:22 PM
nightrunner's Avatar
Mr. Obvious
i know lack of vacuum at idle will cause poor performance from your brakes on a 1/2ton(non-hydroboost) setup
Old Jun 30, 2007 | 04:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So your brakes will hold for one thing.
Old Jun 30, 2007 | 04:24 PM
Spoolin's Avatar
GFYS and STFU
Awesome, so I guess the main reason for vacume is as you mentioned...to determine the health of the engine. That would make sense. Depending on the problem a low vacume could mean bad valves/seats, and possibly bad rings, provided that there is not leak in the vacume lines.
How would an engine perform with no vacume at all at idle?
Old Jun 30, 2007 | 04:26 PM
Spoolin's Avatar
GFYS and STFU
Gotcha, I must of been typing when you posted up! I remember someone had a problem with their brakes...I believe Lurius had a problem with brakes and it was due to not enough vacume!
