TSP 228/228 .588/.588 112 in 5.3?
you shouldnt get too worked up about the rod bolts yet though. members have been spinning their stock ones up to 7k every once in a while and havent lost em. its not like you are going to be spinning that high everyday or the rod bolts wont be your only problem. im shifting at 6400 right now with my cam and truck intake. i probably could spin a little higher and next time i hit the dyno i will check that out but you are going to have some head work done to hit 400 with a 5.3 n/a for sure. you still might not get there, but good luck man.
17,16,15,14,13,12,11 Drvr
that cam won't start to pull in your heavy truck untill 4200-4500 but it will pull to 7k easy lol, just put it in the camaro and get you a nice 220-224 cam on a 112 and the 3200 stall will help it alot. good luck brandon.
there is a guy down in rgv. with h/c,full bolt-ons and putting down 381hp and 3?? tq.
Originally Posted by sleek silverado
I always had the impression that the truck intake flowed almost as much as an LS6 intake?
i think it flows just fine until you get to high rpms, thats why its not worth the time and effort unless you are shifting like 6400+ after all, these trucks werent built to do that so GM didnt make their intakes to do it either
