Truck won't spin a tire ?!?
Old Apr 20, 2013 | 08:29 PM
95_deer_man's Avatar
Default Truck won't spin a tire ?!?
Didn't really know where to put this so mods move if necessary. I recently picked up a 2000 RCSB. The truck has small cam, ported tb, ported heads, 3200 stall, and 4:10 gears with a posi. The truck runs real strong but won't do anything from a standstill. I had a buddy look at the tune and said the torque management was zeroed out. Any clue what else it could be ?
Old Apr 20, 2013 | 09:27 PM
Three6GMC's Avatar
bad converter or trans? my buddys 5.3 blazer does the same thing we are still trying to figure it out
Old Apr 20, 2013 | 09:36 PM
AndysC3's Avatar
Very good rubber on the tires. Lol
Old Apr 20, 2013 | 09:46 PM
bluebommer07's Avatar
i have a buddy that has a cc that does the same he has cam,tune and long tubes and cant spin for dig.. on the other had i have just cam and tune in my cc and from a dig i can spin pretty good.
Old Apr 20, 2013 | 10:12 PM
lycominghunter's Avatar
could it be that the torque management wasn't changed in the tune?
Old Apr 20, 2013 | 10:34 PM
Idk I wouldn't think the trans or converter would be bad because other than not spinning it's runs hard as hell and will chirp the tires and get squirrely on the 1-2 shift. Just feels like it's being held back some from a dig. And my buddy who looked at my tune today said that there wasn't any torque management in the tune. I'm stumped lol
Old Apr 20, 2013 | 10:40 PM
How is the idle on the truck? It could be the TB that is ported giving you the trouble.. Other than that its hard to tell without seeing it first hand or a lil bit more of a description as to it falling on its face from a dig...
Old Apr 21, 2013 | 01:37 PM
It idles just fine to me, I guess I'll have to make a vid or something to show the delay from a dig. From other vids that I've seen of other trucks with similar mods it will blow the tires off from the start, but mines just leaves then it'll pickup pretty nicely but won't even attempt to spin.
Old Apr 21, 2013 | 02:06 PM
tiffo60's Avatar
Any way to record a data log in said situation? That should give a pretty good indication of what could be going on, see if its pulling timing on the take off, etc.
Old Apr 21, 2013 | 08:46 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You mentioned a small cam but didn't list the specs.
The cam could be your problem, but without knowing the specs or how it was installed it would be impossible to say for sure.
Also the stall converter is going to make it feel lazy until you get it up to the stall speed and in the cams power range.
